I cant get NF to print reports on both sides of the paper. Anyone have a solution?
I don’t what printer you has, but you could try playing with.
CURRREPORT.PAPERSOURCE
It could, of cource, also be that the printer driver hasn’t been set up corectly. //Henrik Helgesen -: KISS::Keep it Simple, Stupid :-
Might be stating the obvious, but we simply set up a Windows printer with duplex as the default under the ‘Printing Preferences’ on the printer. Any print to this printer is by default duplex. Works fine on Xerox DC350 laser printers.
If you’re asking about using the printer for printing on both sides of the paper the information you’re showing, it’s just setting up the printer. If you’re trying to print the information on one side of the paper and use a determinated different thing for printing on the other side of the paper (as for example, notes on the back of the paper), it can be also done, but needs some programming (i know 'cos i’d to do it for a customer some time ago). Regards, Alfonso Pertierra (Spain)apertierra@teleline.es
