Hi [mention:83f75ef5a2654d3196286e7b246d1b21:e9ed411860ed4f2ba0265705b8793d05] ,
If you just added field and havent used or put data in table then you can select Schronization Schema as force while comiling / save object.
Still i would suggest to keep a backup of data (if any in the table) before doing it , because with Force Schronization Schema if any data which does not fullfill the new field / key structure that data will be deleted.
Thank you for your reply, it helped me, with “Force” were updated.
What I wanted to try is to make this table sortable by default by “Valuation Date” Descending, but all the columns are fixed (not sortable). I’ve added as a Key to the Table and SourceTableView set to SORTING(Valuation Date) ORDER(Descending) but no effect.
Hey [mention:83f75ef5a2654d3196286e7b246d1b21:e9ed411860ed4f2ba0265705b8793d05] ,
What you want to acheive by the sorting. Do you want sorted data in Page or you want to use the sorted data in code?
If you want to sort the data for page you dont need a key you can do that by page property Source table view and for the report you can add a new key with just the field valuation date and use that during code.
