I am currently having some trouble when I am trying to post all the lines from the journal table to the ledger entry table. I followed the “Posting Routine - 3 Codeunits Approach”, but for some reasons, it only showed the Entry No.(s), other than that, the data in the journal lines aren’t there. The other problem is the first Entry No. is not a “1”, but instead, it is a zero. Does anyone of you have a solution for me? Thanks in advance. I sylvia tsang
Guess we need some more information on this issue. I assume you are using a custom journal/posting routine, as the Navision standard is working fine. Let us know some more details, thanks. Soren Nielsen, moderator Integration/Developer NOLUG
