Hi, this is what the official manual says: ---- Batch Posting When you have created multiple journal batches you can choose to post several or all of them with a single command instead of posting them individually. To post several batches, open the General Journal Batches window and select the batches you want to post. Then click Posting, Post. — Ok, than let’s make a selection and post… I couldn’t find any kind of C/AL - Code making a selection (behind the post-button or elsewhere). That means everything will be posted, or am I wrong? I hope that there will be a change in Attain - Code or in the manual.
:-))) Very funny! You can filter journal line first using your own criteria and then press F11. Only filtered records will be posted. Business Applications Programmer Sertified Navision Developer SIA “Sintegra” Latvia
