i have a seperate batch for each branch ( about 35 branches). with same template…the journal are filled automatically from another application… now i want to post all the journals at a time instead of posting one by one…
how to achieve this…
If some Batches could not be posted (insufficient data filled in or other reasons), you will be warned by message, and rows with corresponding unposted Batch names will be marked.
Hi Sharp Blue,
If Modris answer solved your problem, then please click “Verify Solution”, so that we know that your question can be closed. It’s also a way for you to say thank you to the member who helped you, and to tell other members which question that helped you out.
