Hi all!
We try to “certify” a routing but the system is really slow. It take few seconds , sometimes minutes to get the routing certified.
Does anyone here has seen that problem? How can I resolve that?
Hi all!
How big is your database?
Are there any customisations in Routing area?
It seems it is not fine tuned for performance issues, may be you need to re-create the indexes.
One thing that you can try:
Optimize Tables: File>>Database>> Information>> Tables>> Select all and Then Press OPTIMISE.
This should be done when users are not connected to system.
Hi Taty,
When you certify a routing there are a number of checks and re-calculation performed e.g. Version Management.
Run a code coverage (if you have access) on the certify routine and see if there is bottleneck in codeunits 99000752 - Check Routing Lines and 99000756 - VersionManagement
Thanks Dave . I will try that.
Hi Dhan I will try that solution
