I am trying an uploading opening balances in AX 2009 for vendors from the table LedgerJournalTrans created the template. But when i try and upload the same it says “Total Number of Lines:0”. Successfully imported Lines: 0"
First i exported LedgerJournalTrans Table from AX… after that i filled the excel template(LedgerJournalTrans) with the necessay fields like Vendor Code, Vendor Account type, Offset Account(99999) and Offset Account type(Ledger)etc. after that i went to General Journal selected Data Migration as the Journal Name > Lines > Import Lines button > selected the above template…but the same thing pops up.Number of Lines:0". Successfully imported Lines: 0" Help need a little help please Thanks in Advance
As a test create a journal, then export it, delete the line in the journal and import it and see if it works. Make no changes to the template at all, do not even open it - this proves the import.
You do not say how you are exporting, but if I assume you are using the standard import/export or the Excel wizard then make sure you create an import and import through the same tool as well. As standard there is no import from the lines - is this a modification or a localization? I would remove this from the process and import it thorugh the import tools.
Here is the key factor that is when we insert the journal line , few fields will be filled by system internally . When i try to export how do i come to know that what are all the fields that i need to select ?
You sit down with the export and compare it to what you have keyed and the knowledge you have gained. You then go through trial and error or relying on experieinced consultants in your company to teach you/guide you or show you.
