You can use the Security profiler to check which security key you must activate. If the tool is not installed, you can download it to the following link:
You know, I’ve seen that before but was always leery about trying it. Nevertheless, it provided all the necessary keys to make it happen. Just wish it would tell you which level of access was needed for each key so I could set the minimum level necessary with confidence.
Thanks a lot man!
Just for anyone who might need a quick reference, here are the keys to create a sales order in AX 4.0.
Well, set overall create access on the tables then go into the tables and reduce to view where the user should not hav Edit / Create access on the individual fields.
For example :- Set overall Create access on Purchase Table, then expand the Purchas Table node, and reduce fields to View only where required.
Also, security profiler is handy but won’t be to track certain forms / tables / classes, for this purpose it should be okay though…
