When printing, Navision should ignore the ne-number of the printer name since this number dynaically changes in NT when adding or deleting printers. This i quite easy to solve in codeunit 1.
Does that mean you solved this problem or that Navision should be able to solve it? If you solved it, how did you do it?
Take a look in the downloadsection at http://www.maynavision.net There You’ll find a slightly modified Codeunit 1 for W1 2.50 that does the trick
