Has anyone else had the problem where a users menu has stretched so far across the screen it is impossible to drag back. The windows open from options chosen, but are not visible. We have deleted the ZUP file, but this has not made a difference.
That kind of error was a common in previous version of Nav But deleting ZUP file was more than enough. Menu size is defined in ZUP file. Have you deleted correct ZUP file?
I don’t think that the user has stretched the menu.
I suspect the full-screen-feature causing this problem. Many customers press the square on top-right-screen (maximize-button) to get a full-screen window (causing all NAV-windows to maximize). And many customers do get problems with the menu.
I myself do never use this feature and I have never experienced the problem. Instead I “maximize” only relevant NAV-windows by pulling the window corner.
