hi,
why it happend?
would you give some advises?
thanks
Look for fin.zup file in your PC, and delete it. I believe you can find a lot of post regarding this ZUP file
-TR-
As suggested, delete the .ZUP file and it should resolve the issue. The default location of file is :
C:\Documents and Settings\UserName\Application Data
How kind of ban it happens again and again?
thanks
What version are you using?
There was a patch for earlier versions for this problem.
Thank you first.
NAV 4.0
Yes, this was a problem on version 4. Ask your partner for the fix on this, it should be still available on partnersource.
what is the exact problem? [:D]
It’s a bug and there is a fix for it.
