First of all, don’t expect ASAP thing here, the people here are volunteers and you are not paying them for replies, so have patience.
Regarding solution to issue in hand: Seems there already exists Cronus Sample Database in your SQL Server instance, please check this using SQL Server Management Studio, if required you may like to rename the existing database (Here I am assuming you are doing Demo Installation). Also check if the user has sufficient rights in SQL Server to create a database.
NAV 2009 SP1 installer have the option to overwrite existing database. You need to use custom installtion for this option. On the parameter page set the option “Replace existing database” to yes.
