Greetings,
Scenario: Need to migrate AX2012 r3 cu10 version from Physical to Virtual (Virtual will have different domain, name and IP ranges)
DB : Sql Server 2014
I have two queries:
Does anyone did this before, if yes, can you share the steps he/you carried out.
Our systems people plan to use P2V conversion tool to move the Physical server into Virtual.
- I hope same steps need to carryout as my question-1.
Regards
