AX Server Migration
Hello All,
How can we migrate AX environment from one machine to another in the same domain ?
We are having AOS and DB server on different machines.
Version - AX 2012 R2
Can anybody tell me the steps to perform this operation ?
Yes, you can.
The steps depend on which components you’re talking about. The database? The AOS? The client? SSRS? IIS-hosted web services? And so on and so on.
Hello Martin,
We will be moving AOS & the database both and as database will be moved both reporting as well as analysis service will also be moved.
Users are having client on their local system so we will be updating them independently.
So if you have any such manual or reference guide for the migration,please do share.
I don’t think there is a document that describes exactly all the steps to perform that migration, there is document
http://blogs.msdn.com/b/axsupport/archive/2011/11/07/moving-between-microsoft-dynamics-ax-2012-environments.aspx
that might be a good starting point but it doesn’t cover all the components ( Retail, etc.). If you are performing the migration in the same domain it will be easier since I don’t have to worry about SID’s.
