All,
I have built a new SQL 2005 cluster for my Navision (v4.0) database and want to move the DB from our old SQL 2000 server to this new cluster. I’m having some problems… I have tried a couple of ways to do this restore:
- Restore using SQL Management tools:
If I use the SQL tools to restore the database, there appear to be some problems with the permissions on certain tables - in particular the session table. When a user logs in they get the following error:
‘The session table does not exist as the required object name of Navision_Test.dbo.Session in this database’
- Restore using the Navision client:
If I create a new Database from the Navision client and then attempt to restore a DB backup from the Navision client I get the follow error when trying to login:
'The session table contains a Microsoft Business Solutions-Navision field data type that is not compatible with the SQL Server data type:
Field: Wait Time (ms)
Type: Integer
SQL type: BIGINT’
Both ways restore the database just fine, so there are just some interesting problems stopping me from getting this done. Has anyone encountered this or know how to get around this?
Stevo
