We need to move our Navision database server from a Windows 2K machine + MSSQL 2K to Windows 2003 (64bit) + MSSQL (32bit)
As suggested by our Tech support for navision we created the logins (for existing users in the 2K database) on the SQL 2005 and then restored the backup from the SQL 2K to this new machine.
The database was restored fine but when we try to login it gives “Login failed” error. Can someone possibly suggest what is that we are doing wrong here?
Also, is there anything we need to keep in mind before the move, we are running Nav 4.0?
Is it compatible with 2005?
When restoring do we need to import it as a backward compatible MSSQL 2000 db?
Kindly advise
