Make changes to a form action pane tabs when you log in as a different user
Hello All,
I want to hide certain ActionPaneTabs of a particular form only when I login as a different user or users of that particular user group.
Please let me know how and where should I write the X++ code to implement this.
Please let me know if you have any questions for me
Thanks in advance.
Shankar Iyer :slight_smile:
It sounds more like something you should do through security, instead of writing code. Is there any reason why it can’t be done through security?
What security feature i.e. entry points will help me to hide ActionPaneTabs of the VendTable form.
I already tried to added \Security\Roles\Privileges\VendTableView but I still need to hide some more actionpanetabs of this form
Kindly advice how I can achieve this
If the user doesn’t have access to any button on the tab, the tab shouldn’t be displayed at all.
How to implement that for just for a particular user?
Do I need to write some X++ code or make changes to any properties of the form or add some entry points to the privilege??
Kindly advice
Hi Shankar Iyer,
You can do your requirement by using security, and you can perform it by using the following x++ code…(ax2009)
select firstOnly UserGroupList
Where UserGroupList.userId == curuserid()
&& UserGroupList.groupId == ā€˜STGroup-01’;
if(UserGroupList.RecId!=0)
postJournal.visible(true);
postJournal.enabled(true);
else
postJournal.visible(false);
postJournal.enabled(false);
You surely can assign a certain role to a single user only, if the user should have unique permissions.
Hello Arvind,
I tried this code but we don’t have proper UserGroup setup so this idea won’t work for me.
Is there a way we can find a linkage between sysprofiles and user Tables
When you go system administration > User Profiles
we have two tabs overview and Users… I want to know this linkage works ??
Does anyone has any idea about this
Please advice
Hi Shankar,
If you check on form, you can see that in the code, there is a table named ā€œSysUserProfilesā€ is used.
You can check the code and accordingly use that table.
Regarding your actual requirement, I believe, you should handle the case with security permissions, rather than through code.
Hello All,
I found the solution for this requirement
I wrote the code in the init method of the form without making any changes to the security features of AX2012
select role
where role.Name == ā€œYour roleā€;
select * from userRole
where userRole.SecurityRole == role.RecId &&
userRole.User == curUserId();
if(userRole.RecId)
General.visible(false);
General.enabled(false);
else
General.visible(true);
General.enabled(true);
Thanks everyone for your responses
