Form Control Permissions
I added an ActionPaneTab to a form. This new control can only be seen by administrators but i want the control to be seen by anyone who can access the form. Who has an idea what the problem is?
It probably means that other users don’t have permissions for any button on the tab.
Check the “needed permission” property of the control and change it to specific option(read, update, create, delete) or else if you want to make the control visible regardless user permissions, then you can keep it to “none”.
Hello AnandMallawvarapu7,
The needed permission property is already set to none.
There is only one button on the tab which also has its “needed permission” property set to none.
