Not as standard. You can set a location filter on the inventory valuation report to get a single location. If you need to develop a report then the inventory valuation is the best template as you can run this “as at” a date. Just put a dataitem of location and indent the item and value entry, setting the location filter on the item each time.
I’ve done as suggested… added Location as my first dataitem, indented Item and Value Entry
on the Location property select Code as a group filter.
Are you then saying I can remove the iventory posting group grouping on the item and replace with Location filter? or just add Location filter to my reqfilter fields?
For Item by location report no need intendation.By using matrix type you can do.Download this item by location report[50024] file and import in your application .
