I am trying to get a Inventory Valuation report, group by Location Code.
I found R1001, but Location Code filter in Value Entry DataItem does nor work.
Any one can give one idear how to get this filter - Location code??
Regards
Regards
There is no such report in standard NAV. As far as I know, that is.
Using Location Code Filter will only get you a total containing data from the selected locations (=whitin filters).
Work around is to output the report, stating location code - one by one. [:’(]
Alternatve (an better) is to create a new report, where location codes and group totals are used.
Hey lauana is the R1001 a locatization report or a standard report.
Try to filter you value entry table with location code, if it does then there should not be a problem in the report.
