since now i developed in financials 2.60it, there the fieldnames where in italian; now in attain modifying reports i can still open the table designer and look for the italian translation of a fieldname but it were much more easy if i had a list with the translations of all the fieldnames of all the tables. DOES SUCH A LIST EXIST?
The only solution that i find for the moment, is to use the object deisgner . to run the table and then to use the CTRL+F8 fonction. After you Add columns and then you can see the English Name and the traduction Name. Stéphane VABOIS
