in warehouse entries form…the item description is missing or no value…why? does anybody know how to fix the problem… i want to
hi victor,
the item describtion is missing in both(entry-inward & entry-outward) because there is no entries in the table/form! try entering values and check:)
All the best:)
Hi Victor,
The description is only populated if you overtype/amend the Item description on a transaction - same as the item ledger entry table
so i need to overtype to record the description??
Hi Victor,
It’s a minor change to the code to record the description all the time.
