Is it possible to dynamically change the fields visible property based on some boolean selection?
I have a scenario that in user setup I have a boolean field lets say “Hide Field”
If “Hide Field” is true then I have a (for eg) In Customer Card Name field will be hidden for some specific user? and this should be configurable for some other table and for any field?
I was trying to achieve this using fieldref but fieldref does not have visible property
Thanks Erik. Is there any way that I can configure dynamically for different pages. just want like a control center where if I define a field for a page, that field should not be visible?
Not sure what you mean by “a control center”? If you think of standard functionality without any coding, then no! But you can create page extensions where you can change it.
Control center means I have a Custom page (Control) where I can select any base page along with field, and on that custom page I have boolean field “Hide Values”
so If “Hide Values” is True for a particular field then that field will be hidden on selected base page
Custom Page(Control)
Page Name Field Name Hide Values
Customer Card Balance True
If “Hide Value” true then Balance field will not be visible for some user.
I am trying my best to explain this. I agree that for achieving this I need to do some coding.
Theoretically then you could do it. But it would be the biggest and most breakable app ever created! [emoticon:f395e0ed7f2b4f71a3a75ca0fa47590c]
You would have create a visible variables for all page field controls. And then you would have to create a Control function to all pages to set the variables based on the data in your “Custom Page”.
But don’t do it, even if you could. You would end up with something that would require so many exceptions to avoid users hiding required fields etc.
To me, then it sounds like you are trying to make something, which exists. It’s just called page customizations!
