Hi!
There might be someone here who can tell me how to pick materials from the warehouse to use.
For example: wood to prepare chair
Or is it only possible with manufacturing?
Thanks for the answer, and sorry for my bad english!
Hi!
Hi Yngwie,
There are different ways of doing it. It depends on your actual setup + Granules that you purchased. If it is for manufacturing, then you can create the pick list from the Work Order. If not using it, from the sales Order → Function → Create Inventory pick or create a pick from the Warehouse Shipment…it all depends on your actual setup.
Basically, NAV has 2 different way of picking: Warehouse Pick (Requires WH granule) or Inventory Pick (Different granule). Some customers will simply use a report to do it.
If you are just assembling the chair, you can still use the “Kitting” functionality for that.
Hope this helps.
Thanks for your help Jacques!
It was useful!
All the best!
G.
