Run the Adjust cost - Item entries routine - remember to post cost to G/L - run more than one (normally three times) to make sure cost ripples down to all levels
Check you configuration and see if you are using expected cost posting and where is setp to post to. Also make sure to tick the expected cost box on the inventory valuation report
Most difficult - check for direct journal into the inventory control account(s)
