Installation of Connector for Microsoft Dynamics
[8o|]
Has anyone installed the Connector for Microsoft Dynamics that comes with the R3 Setup Successfully?
I seem to to be getting anywhere with this.
Tried two different setups on different Virtual Machines but NO SUCCESS on either.
I want to Integrate AX R3 and CRM 2013 - i haven’t gone beyond the Installation of Connector for Microsoft Dynamics.
Any assistance please???
See Snapshot below that comes immediately I click Install after all the prerequisites check is successful.
The error says that it can’t connect to the SQL server to which it’s deploying something - this seems to be the area you should investigate.
Martin,
Thanks for your reply.
I have checked the connection and there’s indeed a connection to the database.
And from the log file extract below, I can tell that every check is successful…
2014-06-12 14:10:10Z Performing a registry value version check for prerequisite ‘Microsoft .NET Framework 3.5 Service Pack 1’.
2014-06-12 14:10:10Z Searching for a minimum version of ‘3.5.30729.1’.
2014-06-12 14:10:10Z Version found: ‘3.5.30729.4926’.
2014-06-12 14:10:10Z Check succeeded.
2014-06-12 14:10:10Z Performing a .NET version check for prerequisite ‘Microsoft .NET Framework 4.5’.
2014-06-12 14:10:10Z Checking for the existence of the registry key ‘HKEY_LOCAL_MACHINE\SoftWare\Microsoft\NET Framework Setup\NDP\v4\Full’.
2014-06-12 14:10:10Z Success
2014-06-12 14:10:10Z Searching for a minimum version of ‘4.0.30319.0’.
2014-06-12 14:10:10Z Version found: ‘4.5.50709.0’.
2014-06-12 14:10:10Z Checking for the existence of the registry key ‘HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft.NetFramework\v4.0.30319\SKUs.NETFramework,Version=v4.5’.
2014-06-12 14:10:10Z Performing a domain account check for prerequisite ‘Domain user account’.
2014-06-12 14:10:10Z Performing a local administrator check for prerequisite ‘Local administrator’.
2014-06-12 14:10:10Z Performing a windows installer version check for prerequisite ‘Microsoft Windows Installer’.
2014-06-12 14:10:10Z Searching for a minimum version of ‘3.0.0.0’.
2014-06-12 14:10:10Z Version found: ‘5.0.9200.16384’.
2014-06-12 14:10:10Z Performing an OS version check for prerequisite ‘Server operating system’.
2014-06-12 14:10:10Z Searching for a minimum version of ‘6.0.1.0’ and a suggested version of ‘6.0.1.0’.
2014-06-12 14:10:10Z Version found: ‘6.2.9200.0’.
2014-06-12 14:10:10Z Performing an MSI AX component check for prerequisite ‘Application Object Server (AOS)’.
2014-06-12 14:10:10Z Checking for the presence of the Dynamics AX ‘6’ feature ‘COMPLETE’.
2014-06-12 14:10:10Z Performing an MSI AX component check for prerequisite ‘Client’.
2014-06-12 14:10:10Z Performing a .NET version check for prerequisite ‘Microsoft .NET Framework 4.0’.
2014-06-12 14:10:10Z Checking for the existence of the registry key ‘HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft.NetFramework\v4.0.30319\SKUs.NETFramework,Version=v4.0’.
2014-06-12 14:10:10Z Performing an MSI AX component check for prerequisite ‘.NET Business Connector’.
2014-06-12 14:10:10Z Checking for the presence of the Dynamics AX ‘6’ feature ‘NetBusinessConnector’.
2014-06-12 14:10:10Z Performing a SQL role check for prerequisite ‘Membership in sysadmin role in SQL Server’ on server ‘DYNAMICS01’ for role ‘sysadmin’.
2014-06-12 14:10:10Z Performing a database version check for prerequisite ‘Microsoft SQL Server (Connector for Microsoft Dynamics)’.
2014-06-12 14:10:10Z Attempting to connect to SQL Server ‘DYNAMICS01’.
2014-06-12 14:10:10Z Searching for a minimum version of ‘10.0.2531.0’.
2014-06-12 14:10:10Z Version found: ‘11.0.3000.0’.
Martin Dráb,
I realized that the issue might be SQL server 2014.
I tried the installation on my VM with SQL 2012 and it worked pretty well with no issues at all.
Next next Wizard, and I have my Connector in.
And also, SQL 2014 may just have an issue with MR instalaltions(Compatibility).
RESOLVED.
Apparently, the connector installer included in the R3 Setup was not updated,the one included only works with SQL 2012.
I used this link to get the latest version of connector.
http://blogs.msdn.com/b/dynamicsconnector/archive/2014/02/11/connector-for-microsoft-dynamics-v3-cu-2-released.aspx
I hope someone else won’t have to face this again…
