i have to import the images into the NAV and the clients have requested me that it would be better if jpeg files can be imported into the NAV . so would appreciate if i can get the suggestions…
Hi
Run form no 1 (Company informations), there will be an menu button picture , keep this as ref and do your work
It should be BMP
Hi
Try something like this…
Item.GET(“No.”)
CALCFIELDS(Image);
IF EXISTS (‘C:\NavisionDB\BMPs’+Item.“Brand Code”+’.BMP’) THEN //This where the JPEG file exist
Image.IMPORT(‘C:\NavisionDB\BMPs’+Item.“Brand Code”+’.BMP’,FALSE);
Regards
Paddy…
Are you planning to view these JPG’s or are they just for storage?
Hello
You can quite easily create an Import/export function that import any kind of file into a blob-field in the database. The only restriction is the 2gig blob-field size.
Unfortunately it is not possible to view JPGs directly in NAV, you have to write a Wrapper in order to do that. Use google or bing to see if it does not already exist.
Best Regards
Palle Arentoft,
Dynamics NAV specialist
www.NAVspecialist.dk
