hi friends…
today i have tried import item details…through template wizard…
…import done successfully but when i open the item details form it shows grid is empty.
i was open the invent table(table) the records are inserted. but its not shown in form level…
…is there any one know the solution plz let me know…
thanks in advance…
Harish
February 8, 2012, 11:12am
2
This issue was discussed so many times before. Please search.
Also as a best practice whenever you import data, always remember to run consistency check tool (under Admin > Periodic > Database)
mjanzar
February 8, 2012, 12:09pm
3
items are added in many tables and not only in inventtable, thats why they are not appearing the form, they are 4 tables. when using the template wizard, select the following tables:
InventItemInventSetup, InventItemSalesSetup, InventTable, InventTableModule
if you fill these four tables correctly then the item will be shown the “item details” form.
hope this helps…
hi,
This is already discussed here. Navigate to link below.
http://dynamicsuser.net/forums/t/47639.aspx
Thanks & Regards,
Mehul Thacker.
