i have a different problem.I have imported data through excel template in my inventTable and all related tables.The import is successful. But when i open the form i can not see my data but if i open the table i can find my records.Could u tell why this is happening.
For the ‘InventTableModule’ are you importing 3 records for every item?
Next question is - did you run consistency in check mode? If answer to the first question above was true, then try running this in fix mode and see whether it resolves the issue. To be on the safer side, you may want to take a backup of database before you do this.
For ‘InventTableModule’& inventTabel&InventInventItemLocation these are the tables i imported only one record for each table with the same Item number & i filled only mandatory fields.
I run consistencecheck in both fix error and check again i have same problem.i try to another modules i successfully import the data.
