I want to convert Numbers to text format. I know method but how to call this method in Reports not in jobs.
Global::num2Text(1000);
in place of 1000 I want ‘Total’
I dont Know How to assign Amount field in total variable in display method
How to write display method to convert the total value in text?
Balu
HI Balu,
Have you declared the total variable in one of the methods or in Class declaration.
d_arc
October 1, 2012, 4:32am
3
Hi Balu,
if you’re using ax 2009, u need to create display method in the report and assign it.
but if you’re using ax 2012, u need to add field (‘Total’) in the temporary table and insert the value into that (‘Total’) field from Report Data Provider class.
Dar
I declared Total variable in Classdeclaration.
but Assigning of total variable in display method is throwing an error i.e Syntax Error.
Code:
display AmountCur Total()
Total = VendPurchOrder.Amount;
return global::num2Text(Total);
Total = VendPurchOrder.Amount; …It throws Syntax error
I dont know how to assign this variable. Pls help me…
d_arc
October 1, 2012, 7:00am
5
Hi Balu,
maybe u can try using this:
display str Total()
Dar
d_arc
October 1, 2012, 7:42am
7
Hi Balu,
try this:
display str60 Total()
return strfmt("%1", Total);
Dar
Mr Balu, you May assigned Total Variable as Str so Change the DataType of Total Variable to Int in Class Decleration. Hope it wil work
Hi Balu,
Try this
in class declaration
AmountCur Total;
and in display Method
display AmountCur getTotal()
Total = VendorPurchOrder.Amount;
return Total;
Hi
I solve this Issue.I wrote this code. It;s working
display str Total()
return global::numeralsToTxt_EN(VendPurchOrderJour.Amount);
Balu
