I am developing a report that contain total variable of decimal type now i want to convert it into text like 1120.20 into one thousand one hundred twenty and twenty paise.
I also hired about format() but i don’t know how to use it in my report.
Please help me and give me some suggestion / example. i will very thankfull to you…
Neel
Review the check report to see how it converts numbers into text
I am using following code :-
RoundLoop, Footer (8) - OnPreSection()
CurrReport.SHOWOUTPUT(VATAmount = 0);
Check.InitTextVariable;
Check.FormatNoText(NumberText2,ROUND(tot),’’);
tot :- decimal type variable.
NumberText2:- text type variable.
It is showing message " The array dimensions must be identical " at the time of report compilation.
Set Dimensions to 2 for NumberText2 variable
Dear Mohana,
Thanx for your reply but i am converting numbers to text first time so please tell me how i can set dimensions for variable.
Thanx
Select the variable and click View–>Properties
set 2 in Dimensions
I write in SourceExpr “NumberText2[2]” and there is no “Dimensions” Properties in the properties of this variable.
But problem not solved.
I am talking about the variable under global variables not in sections…
are you a technical consultant?
Lot of Thanxxxxxxxxxxxxxxxxxxxxxxx
Mohana
