Hi frndz,
I have a form where i have a with BOMID as a lookup. It retains a previous selected value when i open the form next time.
I want to reset it.!!!
can u please suggest me what i can do for this?
Thanks & best regards,
Ramya
Hi frndz,
Ramya
Can you show us the code?
Did you try with CLEAR();
There is also a form property called SaveControlInfo that you can set to “No” if you never want it to open on the last record that was viewed, regardless of where the form is opened from.
Hello matt,
do we have that form property in AX 4.0?
Thanks & Regards,
Ramya
We are talking about Navision.
thanks for ur reply…
my problem is in AX 4.0?
Thanks & regards,
ramya
Then you should have posted it in AX forum not in NAV forum …
