I have created Transfer Order in AX 2012 R2. Now I have to Post [Receive] this created Transfer Order using AIF service provided by AX 2012 R2 [i.e. InventTransferOrderPostingService].
Can you please help me out on how can I use this service in order to POST[Receive] my already created Transfer Order in AX 2012 R2.
Do you really want to use a document service for that? I wouldn’t say that you want to create a journal outside AX and import it to AX; you want just to say AX which order ID to post (maybe with some parameters) and AX will do the rest.
A custom service sounds as a much better choice to me than a document service.
I mentioned document service because I found one that is provided by AX in standard [InventTransferOrderPostingService]
Yes, I just want to POST [Receive] my Transfer Order using AIF. Can you please help me how can I achieve that using custom service if not Document Service?
All right, so the document contains InventTransferParmTable and InventTransferParmLine records. They define what should be posted. The service then call InventTransferUpdShip or InventTransferUpdReceive to post the document.
I too am facing the same problem. The Ship portion works just fine if you set the QtyShipNow and QtyShipNowSpecified fields on the InventTransferParmLine records.
I expected the receive to work by setting the QtyReceiveNow and QtyReceiveNowSpecified fields. I even set teh ReceiveUpdateQty to ReceiveNow enum value and ReceivedUpdateQtySpecified to true in teh InvTransferParmTable to no avail. The error message I get is “Ship now quantity must be positive.” The message itself is surprising because we are on the receive side of things. I even tried to set a value for QtyShipNow, but that didn’t make a difference in the error message.
The post has been out there for some time with a few followers.
This error comes from inside AX, not from the web service interface. Therefore you can go and debug the code to see what’s going on (see Debugging Services in AX 2012).
