I am creating a form in a job using
Form form;
FormRun formRun;
FormBuildDesign formBuildDesign;
FormBuildDataSource formBuildDataSource;
form = new Form();.
formBuildDataSource = form.addDataSource(“Table”);
formBuildDesign = form.addDesign(“Design”);
formBuildDesign.widthMode(1);
formBuildDesign.heightMode(1);
form.design().caption(“Caption”);
I am adding a grid to the form by
formBuildGridControl = formBuildDesign.addControl(FormControlType::Grid,“Table Grid”);
and than fields (they are named F1, F2, …) to this grid by
for(ii = 1; ii < 5; ii++)
formBuildGridControl.addDataField(formBuildDataSource.id(),fieldName2Id(tableName2id(“Table”), strFmt(“F%1”,ii)));
Form is created, grid is added and visible but when I try to sort by a field I get
Invalid sort field type.
and I do not see filter function.
What I need to do to have sorting and filtering available?
I can’t reproduce your problem.
Can you tell me whether following code works in your system?
Form form = new Form();
FormBuildDesign design = form.addDesign("Design");
FormBuildDataSource buildDs = form.addDataSource("CustTable");
FormBuildGridControl grid = design.addControl(FormControlType::Grid, "Grid");
Args args = new Args();
FormDataSource ds;
FormRun formRun;
buildDs.table(tableNum(CustTable));
grid.addDataField(buildDs.id(), fieldNum(CustTable, AccountNum));
args.object(form);
formRun = classfactory.formRunClass(args);
formRun.run();
ds = formRun.dataSource(1);
ds.queryBuildDataSource().addSortField(fieldNum(CustTable, AccountNum), SortOrder::Descending);
ds.executeQuery();
formRun.wait();
By the way, if you post code that can be copied to AX and run without extra work, you’ll have a better chance that somebody will bother.
The fields has a type String with size Memo. With limited length everything works correctly.
Ah, that’s by design.
You should have debug static design first - if you debug too many things at once, you easily miss where the problem lies.
I hope that my code helped you at least a little; I would hate to hear that I just wasted my time.
It help me but with different tasks
