I got a setup form, at form load ,I want to filter by the Status field, all the Active must be on top and Inactive at the bottom,when I create a new item if its inactive it must be at the bottom when I save the same with Active it must be above the inactive.
am looking for directions or an example.
You can try the below code to sort you form in the init method of the form to filter when you run the form.
QueryBuildDataSource qbds;
str status;
int i;
status = "Active";
qbds = someTable_ds.queryRun().query().dataSourceNo(1);
for (i=1; i<=qbds.sortFieldCount(); i++)
info(fieldId2name(qbds.table(), qbds.sortField(status)));
Please try and let me know for any queries.
John
The status field has 2 options which is Active and InActive, I want to display both with the Active on top and InActive below
Did you try the above solution?
Yes i did, i have replace someTable_ds with my datasource name, i get object not initialized error
you have to initialize the querybuildrange class
public void init()
QueryBuildRange qr;
str status;
int i;
super();
m_vSplitter = new SysFormSplitter_X(vSplitter, gridContainer, element);
status = "Active";
qbds = IMXGoal_ds.queryRun().query().dataSourceNo(1);
qr = qbds.addDataSource(IMXGoal).addRange(fieldNum(IMXGoal,GoalStatus));
info(fieldId2name(qbds.table(), qbds.sortField(GoalStatus::Active)));
what am i doing wrong here?.still getting object not initialized.
Can you share the xpo file to me?
Hi John,
Is there any other option for that?
