Filtering Records in Grid
I have a form which has a field “Posted” which is type “NoYes”.And i have a filter field of type “AllOpenPosted”(combo box).
I want to filter records in such a way that when i select ‘Posted’ in the combo,the records whose “posted field” are checked should be displayed.
selecting ‘open’ in the combo, should display the records whose posted field are not checked.
I followed this link - msdn.microsoft.com/…/hh745335.aspx
Unable to find which part i’m missing.Can anybody please help me .
Rajee
Can you explain your problem and show us your implementation? Otherwise we can’t tell “which part you’re missing”.
Hi Martin,
Below is the form which i have created.
And following are the properties of ‘Combo box’ and ‘Posted’ field in table and form .
And i have followed the same steps in this link - How to: Add Filter Controls to a Simple List Form | Microsoft Docs
While specifying query,Is there a mis-match because the ‘Posted’ field is of type “NoYes”?
Can you show how you set the value of range?
Hi,This is the code which i have written
This code is wrong:
qbrInvoiceJournal.value(AllOpenPostedField.valueStr())
You want rather something like this (it should be self-explanatory):
switch (AllOpenPostedField.selection())
    case AllOpenPosted::All:
        qbrInvoiceJournal.value(SysQuery::valueUnlimited());
        break;
    case AllOpenPosted::Open:
        qbrInvoiceJournal.value(queryValue(NoYes::No);
        break;
    case AllOpenPosted::Posted:
        qbrInvoiceJournal.value(queryValue(NoYes::Yes);
        break;
Thanks Martin! It Works fine now.
I did the same earlier,but dint call the function in the appropriate place
Hi Rajarajeswari,
You can refer the form called “BankReconciliation” in Datasource init and executequery methods.
Thanks & Regards,
Britto John Baskar.A
