when am trying to create a new purchase order it is taking a number automatically like’ 000450’.up to now am ok.but suppose i deleted a existed record “000420”.Now i want to create a new purchase order with the same number 000420.
If you have set the system to automatically generate numbers you cannot, although you could rename it. If the asutomated number sequence is set it will fill in the number, but you could not specify an exact number unless it was manual.
when ever i am enter the item number in the purchase order details form then unit price will be coming automatically and net amount will coming by the multipication of quantity and unit price how it will come?
Really i don’t need that option.as a developer i have a small doubt eighter it is possible to change or not? anyway i got the option from u.
Now another problem rising after setting the namual also it taking the PO numner automatically and also givies the worning as Must fill the Vendgroup,Language Fields. i didn’t get any field in the creating of new PO.Plz give me solution
i just checked the option what the adam told in the above.ie continious to manual.
then again i changed Manual to continious.Now am trying to create a new PO it showing 2 warnings Language must be filled in,Vendor group must be filled in .
But am not getting any option to fill the vendor group in that forn .plz give me suggestion
Am working on vpc only.before it is working fine and it is not asking any vendgroup or language.after i try to change the PO number settings continious to manually then onwards only am getting the warnings ,plz try to give me solution
The number sequnce for the PO has no bearing on the other header information, the vendor group and language must come from the vendor as they are different per vendor,. as a test change teh number sequence back. If it works I would say you have had some development work done or you are doing something you have not yet explained.
in the Administration group Language and Buyergroup details not filled when am creating a new PO.i filled the Language by manually.But i didn’t found the field called **Vendor Group .**still am getting the same warnings
You imply earlier in this post it was due to the number sequence setting. We told you it was not. Now tell us what else you have changed, because as you correctly state earlier, it was working, so clearly you have changed something, whether data or coding. Also describe exactly at which point the message is being presented, and post the message into a reply.
