In My AX system i dont have “X++ Lisence”
But i wan to edit some classes from (Sys & Usr Layers)
Is it possible.
Share your suggetions…
Thanks In Advance…[:)]
Is it possible.
You need It[:)]
Hi Bobby,
Make in the changes in the classes — methods() after that export the class and import it… then the changes will affect…
Naresh kolli
You need X++ license…
Well you can do it as Naresh Kumar Kolli’s way, but u may have one problem sometimes when u do an import then export way the code is imported and everything is fine but sometimes it will not take effect you have to make sure by debugging it to make sure. but i suggest you have to bring the license because its so boring to do import and export
Why do you want to do something, which you are not supposed to do???
Have your license.[:)]
