Export / Import problem
I messed up and accidently changed the actual class instead of the class in the project where I make changes. So when I did my last export, I got an error saying I changed the real class and not the project. So how do I resync things? I’m new to AX and I could not figure out a way.
Thanks in advance!
You can simply add back your modified class to the Project and then export/import.
