Aiman
1
How do I print the packing slip to a different printer? We have a daughter company and when we booked the packing slip is printed automatically there.
The printer is defect there, and I will adjust to a different printer in AX 4.0
Please share your experience
Thanks in advance
ThomasP
2
I don’t know if it works on AX4 but you can try the following code that works in AX2009:
in the your report’s init() method :
str printer;
printer = ‘\\path_to_your_printer’;
this.DeviceName(printer);
this.setTarget(printmedium::Printer);
this works with a network printer.
regards,
Thomas
Aiman
3
Hi Thomas,
Thanks for the reply.
There is a simple setting in AX to change the printer for Packing Slip without code change.
regards,
Aiman
