I am using AX2012 R2 CU7. Our shipmentprocedure has changed and since 2 weeks we ship output orders from projects (item requirement) and salesorders in the same shipment. Now we have some problems with printing the packingslip directly from the shipment, because it’s just printing packingslips from item requirements or from salesorders (not both at once).
On shipment you have the parm 'included order types", this parm is set to ‘All’. So I expect that AX will print also both packingslips. Is there a solution for this problem?
