Greetings,
My company has been using AX since '06. [Originally, we were using the Thy service module for all of our service orders.]
We performed an upgrade to AX2009, and at that time switched to the service module that Microsoft provides with AX 09.
This has been working fine. Recently, it has been decided that we would like to bring the equipment returned for repair to an inventory location in AX; something we have not done in the past. Previously we issued RA and just kept incoming repairs in a designated physical location with the AX relationship being the service agreement and consequent service order only.
The initial meeting produced the following:
First we created a new warehouse called “service” with two repair locations; one for warranty and one for billable equipment on our test server.
- Create service order and provide return authorization.
- Using item requirements for the new service order, make a negative requirement for the part number and serial number of the equipment coming in.
- When the equipment is received, execute the pro-forma invoice placing the equipment into one of the two locations in the service warehouse.
- The equipment stays in inventory until work is complete, at which point it is then picked out of inventory through item requirements, creating a wash cost-wise.
The problem is that bringing the item back into inventory “out of thin air” like we are, the system is counting dollars and adding to the GL account, even though it is being picked back out to the service order. Since we cannot modify the inventory model groups and dimensions on the equipment, is there a way to bring these items in transparently? is there a different way to track the equipment in AX? We need, part number serial number and cost at minimum.
I am working on this in the AX-09 test environment and am willing to experiment with any suggestions. Thanks very much.
