I’ve a queries about round off in exchange rate.
If i agree with following round off numbers:
1.2343 round off to 1.234
1.2345 round off to 1.235
1.2347 round off to 1.235
how much i should set for my general round off ??
The number decimals allowed in the General round off are only 2
that means u can take upto - 0.01
if u put this to 0.01 - you will get 1.23 for 1.2343 and if u put 0.001 in general round of it will become zero and b default it will take 0.01
I think u need to increase the number of decimals…
If i put 0.02 , how much i get from 1.2343 ?
By accounting practice, rounding off must be 0.01
general round off will not work for exchange rate conversion.
by default it will display 4 decimals
inform your tech that change EDT for exchange rate conversion form and change form control on table lelvel in AOT
it will return 1.24
if u want 3 decimals on exchange rate, change form control only for 3 decimals and enter manaully exchange rate as 1.234 , 1.235 etc
I believe no round off should be other than combiantion of 1 and o. e.g. .01,0.01,1.01 etc. others give wrong interpretation.
This is Maria. I have query on decimal values.
i have a decimal value a= 8.34512
when im rounding it or finding the abs … it is giving like 8.35
i would like to get 8.34, i dont want to round off … i want to truncate the remaining decimal. I meant i wanted to get the result as 8.34 and i dont want 0.00512
How should i get these ?
Please advise.
I Found Below in Axapta…Hope It Helps a Bit…
= 0.01 |
= 0.10 |
= 1.00 |
= 100.00 |
98.765.43 |
98.765.40 |
98.765.00 |
98.800.00 |
98.765.43 |
98.765.40 |
98.765.00 |
98.700.00 |
98.765.43 |
98.765.50 |
98.766.00 |
98.800.00 |
I Found Below in Axapta 2009, Hope It Helps a Bit…
| 98.765.43 | 98.765.40 | 98.765.00 | 98.800.00 | |
| 98.765.43 | 98.765.40 | 98.765.00 | 98.700.00 | |
| 98.765.43 | 98.765.50 | 98.766.00 | 98.800.00 |
