Data Refresher (aka Integration Designer) kicked up a fuss when it saw the GL with dashes for the 1st time, but a load ran successfully, and it looks like FRx is can work with the result. We’ll see if smoke comes out anywhere else.
Question: It was suggested to populate No.2 with the G/L codes without the dashes and have FRx use those codes instead. I’ve hunted around, but can’t see how you would do that. Any pointers would be appreciated.
