Special Characters in the Master Record Key Fields
Just wanted to check if there is still an issue in NAV where added *'s into the key fields can have a problem with the setfilter command.
Anyone experienced it recently? Dealing with a 3rd party for a customer who wants to use *'s in the Item No. field but I am worried this will reek havok on the MRP engine.
t
Hi Tony,
I haven’t heard that this should have been solved, as a general rule then it’s still not recommend to use * in you fields.
Yes it’s not going anywhere [:)],
I have tested it. ‘*’ acts as a wildcard.
-TR-
