I have made a table similar to Permission ( table 2000000005) which I call TempPermission. I loop through the Permission table (1. Data Item), and write data to the TempPermission table. When I reach the next Data Item, which is a Integer System Table (2. Data Item), I want to display my data from TempPermission. I refer to the TempPermission fields in the Integer Data Item section (ex. TempPermission.“Role ID”).
Some of the fields are displayed correctly (Role Id and Object Id), but not Role Name and Object Name which are flowfields with a Lookup CalcFormula. The fields are blanc. The fields of data type option displays 0 or 1 instead of the option values.
If I move the output to another section, this problem does not accour. The data is correctly stores in the TempPermissin table.
In newer versions of Navision there is also an “automatic” calculation of flowfields in reports and dataports (may be XMLports, too) if they are used in a section’s textbox or as dataport fields, respectively (but only if the source expression is simply the field itself and not an expression containing the field…)
