Dear All:
I create a flowfield in table, but it is not show on the form or table, but if you drill down that flowfield, the value is there. could anybody help me with this.
thanks!
Dear All:
thanks!
Can you show us the CalcFormula for that field…
Lookup(“Purchase Line”.“PO Date” WHERE (No.=FIELD(Fabric item No.))). The flowfield is created in the item table.
What do you want to do if it has more than one line?
Use Count method in FlowFiled and ondrilldown it will show the records…
hi Soyy,
Did you ever find a solution to your problem? If you did, would you mind sharing it with us and if any of the posted answers helped you on the way, then please verify them.
Thank you.
