When I click on inventory management-> common forms → article details the form shows all the rows (image) but if I call the same “menu item” from a custom button only shows the first row.
Well, i believe that your custom button is calling a menu Item of display type , and the current args will be carried by that object.
So to show all the records and not only the one in direct association, try to place this code in a normal form button(not menu item) in the clicked method:
Args args = new Args(); formRun formRun; ;
args.name(formstr(“PurchTable”)); formRun = New FormRun(args); formRun.run(); formRun.detach();
This will open the form Only, and will not filter by the current record.
