How to filter the records thru a menu button in form
Hi Everyone,
in form is it possible to filter the records when i clicked the menu item button.
for ex,
we ve 4 records . in tat a field is there called “status”
under tat we r having approved for one record and rejected for other three records…
nw if i clicked the filter menu item button means i need to get tat approved records alone… other 3 shud be deleted…
With Regards,
M.Madhan Kumar.
HI Madan,
When you click the menu item button the records which with approved status should be filter…rest all records you want delete it…
In the menu item button clicked write a select statement query where status equal to approved,then it wills how only the appoved records when you click it.
Naresh Kolli
Filtering the records does not mean deleting them…
ya ur right kranthi… so it shud display the filtered records alone… so wat i ve to do nw…
Hi Madhan,
Overiride the executequery() method in form datasource level…add the follwing line of code…
this.query().datasourcetable(tablenum(tablename).)addrange(fieldnum(tablename,status)).value(Status::Approved);
call the executequery() method in menuitembutton clicked() method…
Naresh Kolli
