Hi
Here Is Issue and This is Code…
Item Vendor - OnPreDataItem()
IF ExportToExcel THEN BEGIN
i:=1;
EnterCell(i,1,‘Item Vendor Catalog’,TRUE,FALSE,’’);
i+=1;
EnterCell(i,1,‘Vendor No.’,TRUE,FALSE,’’);
EnterCell(i,2,‘Item No.’,TRUE,FALSE,’’);
EnterCell(i,3,‘Variant Code’,TRUE,FALSE,’’);
//XlWrkSht.Range(‘C+ Format(i)’).HorizontalAlignment := -4108;
EnterCell(i,4,‘Lead Time Calculation’,TRUE,FALSE,’’);
EnterCell(i,5,‘Vendor Item No.’,TRUE,FALSE,’’);
//XlWrkSht.Range(‘E+ Format(i)’).HorizontalAlignment := -4108;
EnterCell(i,6,‘Default’,TRUE,FALSE,’’);
END;
Item Vendor - OnAfterGetRecord()
EnterCell(i,1,“Item Vendor”.“Vendor No.”,FALSE,FALSE,’’);
EnterCell(i,2,“Item Vendor”.“Item No.”,FALSE,FALSE,’’);
EnterCell(i,3,“Item Vendor”.“Variant Code”,FALSE,FALSE,’’);
//XlWrkSht.Range(‘C’+ FORMAT(i)).HorizontalAlignment := -4131;
EnterCell(i,4,FORMAT(“Item Vendor”.“Lead Time Calculation”),FALSE,FALSE,’’);
// XlWrkSht.Range(‘E’+ FORMAT(i)).NumberFormat := ‘@’;
EnterCell(i,5,“Item Vendor”.“Vendor Item No.”,FALSE,FALSE,’’);
// XlWrkSht.Range(‘E’+ FORMAT(i)).HorizontalAlignment := -4131;
//XlWrkSht.Range(‘E’+ FORMAT(i)).WrapText := FALSE;
EnterCell(i,6,FORMAT(“Item Vendor”.Default),FALSE,FALSE,’’);
i:= i+1;
END;
Item Vendor - OnPostDataItem()
Integer - OnPreDataItem()
SETRANGE(Number,1,ExcelBuffer.COUNT);
Integer - OnAfterGetRecord()
IF Number =1 THEN
ExcelBuffer.FINDFIRST
ELSE
ExcelBuffer.NEXT;
XlWrkSht.Range(ExcelBuffer.xlColID+ExcelBuffer.xlRowID).Value := ExcelBuffer.“Cell Value as Text”;
Integer - OnPostDataItem()
// Start Excel
ExcelBuffer.CreateBookAndOpenExcel(‘Item Vendor’,’’,’ ',USERID);
//ExcelBuffer.CreateSheet(‘Payment Captured Detail’,’’,’ ',USERID);
ExcelBuffer.AutoFit(‘A:F’);
ExcelBuffer.GiveUserControl;
END;
// Stop Excel
EnterCell(RowNo : Integer;ColumnNo : Integer;CellValue : Text[250];Bold : Boolean;UnderLine : Boolean;NumberFormat : Text[30])
ExcelBuffer.INIT;
ExcelBuffer.VALIDATE(“Row No.”,RowNo);
ExcelBuffer.VALIDATE(“Column No.”,ColumnNo);
ExcelBuffer.“Cell Value as Text” := CellValue;
ExcelBuffer.Formula := ‘’;
ExcelBuffer.Bold := Bold;
ExcelBuffer.Underline := UnderLine;
ExcelBuffer.NumberFormat := NumberFormat;
ExcelBuffer.INSERT;
When i run Above Code i Got This Error…
Microsoft Dynamics NAV
The Excel Buffer already exists. Identification fields and values: Row No.=‘3’,Column No.=‘1’
OK
any Suggestions…
Thanks In Advance,
Akil
